qbnkiller
Conflaguration Specialist
Hey peeps, as many of you know, I had been working with SCE to get them to make a set of their Titan ICS head gaskets (the ones with the integrated o-ring wire). After working with them for almost a year, they sent me my first set. I took all kinds of pictures of them and placed them on this forum for people to see. I had the engine built, using these gaskets, back in January or so. The engine sat on a stand until I finished gathering everything up for the build.
FAST FORWARD TO FRIDAY APRIL 29...
So I get a call that they were done with the truck (within 1/2 hour of starting it up) and we have a problem. As they were filling the radiator up with coolant, they noticed a small dribble of coolant leaking from the engine somewhere. Took the light to it, and thought they saw it coming from the area btween the heads/block. They put a pressure pump in the radiator, and when they started pumping, it was like Niagra Falls! Coolant pissing from all over around the heads! So I call the engine builders..they believe it is in the gaskets. I call up SCE...apparently, there has been 3 revisions to the gaskets for our engine specifically to corect coolant leak issues.
Now I have to tear it all apart to replace the head gaskets. The truck is completely done....I mean all done. This is a kick in the nuts if there ever was one! I am so F-ing pissed!
This is a warning to you who are contemplating buying a set of these right now....WAIT!! It isn't a full-bore production piece yet! Learn from my mistake!
...now where's my damn shotgun!
