Sealing a cracked block or head???
just a 6
R.I.P MyClone
If you have a hair fine crack in your block or head, what is the best way to seal it until you have time to replace the cracked part?
Bars leak or is there anything better???
just a 6
R.I.P MyClone
it's a hair fine crack just above and between the freeze plugs on a Dodge 4-cylinder block. You can't see it with your eyes only, that's how fine the crack is.
Sy769 said:
Where is the crack?
warmpancakes
grind it to a V shape and clean it goos then jb weld it or actually weld it ive had JB hold for 2 years possibly longer (I sold the van)
just a 6
R.I.P MyClone
Thanks but I was going to do that later, i don't have time to remove the manifold to access the crack right now, so i wanted to try bars leak or something better until i have time to JB weld it.
Anybody heard of "water glass" ???
leroy
Bars Leak is worth a try. Some new vehicles come with Bars Leak as an additive.
Jim
just a 6
R.I.P MyClone
I just got back from the parts store with CRC liquid glass sealer. It suppose to be better then bars leak. I'll keep you guys updated, ok/
Jim
stariy
EPOXY.
When I was in service, we had blown blocks every week – (minus 50 degree C antifreeze and oil froze up). We used EPOXY and it works just fine. I am not sure what kind of EPOXY was it.
