Searched and read almost every post, BUT....
Tophatjimmy
Syclone FNG
I have still have a question about the EGR and IAT temps.
I made a DM log just cruising my route home from work today paying attention to my IAT's to make sure my IC pump was working and moving enough liquid.
Here's what I noticed. At idle my IAT's were around 104-108* F they would creep up as I got moving and then once I leveled off to cruising speed (45-48mph) and the EGR opened up (45-75%), my IAT's climbed up to 152-159* and pretty much stayed there. Once the EGR closed the IAT's almost immediately went back down to 106-115*.
Is this pretty normal? Should I bother blocking off my EGR? i know that's the popular thing to do, but my mileage sucks as it is and I don't want to risk any more detonation than I have to.
I was hoping for lower IAT's, like sub 100* temps. I have an upgraded, hot-wired IC pump, a fan on the lower IC and my own version of the "Blade of Death" IC scoop, shouldn't my temps be lower?
BTW, it was prolly about 55 - 58* here today.
This weekend I'm going to flush my IC system, run a new lower coolant line and put in a section of clear hose up by the upper IC so I can view coolant flow.
Anyway, just curious.
TYRODD
My ass. Look at it.
Re: Searched and read almost every post, BUT....
Plug off the EGR vac. lines and try it out.
I bet you'll see a big difference :tup: Your IATs should be lower than what you're seeing with the valve closed, since the upper intake wont be heat soaked...
I'll warn you about the clear tubing, it looks cool for a little while, but dang it gets nasty in a hurry :lol:
Flyin Ryan
hated cuz he drives fords
Sounds like normal operation of the egr valve to me.. which is why I deleted it. I couldn't stand how quickly it heated the intake temps up.. It would lower back down for me once the egr went off but if your crusing at the same speeds for a while.. that god damn egr valve is open and heating the hell out of everything.
Only thing with deleting the egr valve is that you'll fall any kind of visual emissions testing and if your chip doesn't have a setting to disable the egr operation then you might get an error code once in a while when the egr is suppose to come on but umm it's deleted so pop goes the error code up on the dash for you to see.
Yup that sound normal to me as well for IAT temps when the EGR is one
