Sensor assistance
Damian
I worked on the Ty yesterday, got the pieces put back together for the intake and started her up. She runs great when the engine is cold, when it's hot, it makes the knocking noise I've been dealing with, which is why I don't drive it. So what sensors are used in closed loop and not in open loop?
Damian
Re: Sensor assistance
One thing I've read so far is that you are only supposed to tq down the knock sensor to about 12 in lbs, I snugged it down pretty good but it ran good for close to two months before it started to make the noise.
Peter
my Ty and me 25+ years
Just to be sure, are you asking about an audible knock, or a knock detected by the knock sensor?
The knock sensor will not cause a knock, so the torque is not important. It just detects engine knock.
An audible knock with correlation to engine temperature could be any number of things. Anything having to do with oil viscosity, such as bearings (hope not) or lifters could change sound with engine temperature.
It could also be simply injector noise, or sometimes the fuel pressure regulator will make some noise. Or it could be an exhaust leak when the exhaust manifold expands, or a pipe expands. Or maybe even the exhaust pipe is hitting something.
Need more information...
good luck
Damian
It's an irregular audible knock that only happens when the engine is up to temp. The engine will have little to no power when it's knocking. I drove it to the muffler shop today and it ran smooth as hell when it was cold, got warm it ran like crap.
I doubt it's the oil since I've changed it twice since the knocking started.
Damian
If its an oil issue, I'm using 10w-30 Mobil 1, what should I use then? This oil change has about 50 miles tips on it. I have no metal shavings anywhere. I'm to the point where I'll try anything.
