Separating Pork Chops from Torsion Bars
crazykaese
91ProtoTy/IndyPaceTribute & Sawzall Master
I am stripping a chassis and I got the torsion bar crossmember out with the torsion bars and I can't get the pork chop keys to come off the ends of the torsion bars. They look real rusted - any ideas?
gjp
another post whore
Re: Separating Pork Chops from Torsion Bars
soak the crap out of them in some pb blast or something like that. Mine just fell off. got to love the rust free nevada trucks
Daron
Mine were difficult to get off when I wen to Jeffs coil overs. I soaked them with some wd-40 like stuff and then resorted to the slide and slam technique. Since we had already remove the lower A arm I just grabbed the torsion bar and pushed it toward the back of the truck, then yanked it forward real hard. It took a few wacks but they both came off.
Edit: FWIW the torsion bar crossmember was unbolted...
If the lower arm is already disconnected from the torsion bar (otherwise use a sledge hammer and whack that toward the front of the vehicle), have a friend stick a pry bar in the slot of the torsion such that its only against the port chop (not the torsion bar) Whack the head of the torsion with a sledge hammer and push it back. This will break the rust bond and it should slide out. If you don't use apry backk the torsion bar and pork will both bottom out at the back of the crossmemeber.
