Lynn D. Brown
Hey, have any of U guys taken your Power Steering pump apart ? Since I have everything apart and got a ZQ8 exchange Pwr Steer gear Box, I will have to refill the whole system and bleed it. So, I thought while it was easy to get at I would replace the 100 K PS pump also w a Rebuild.
Well most all of the rebuilds I got from AZone had the Hex cavity in the pump shaft stripped out, and U need this cavity to remove/install the pulley. The one on my old pump (which still works) is perfect, so I don't want to give it up for a reamed out one. Well the Core 4 a Pump w Reservoir is $50. (+ $10. more to boot), vs a Core of $15. for the pump removed from the reservoir. So, I can save $45. when keeping the Core.
The only way I can see to remove the pump from the reservoir is w a Slide hammer. I guess I can press it back w clamps. Anyone done this ?
