set timing
Mike
Does anyone have the link on how to set timing? Is there anything else that i must do before setting it besides disconnecting the tan wire?
Re: set timing
Unless you want to check TDC (our dampeners have been known to slip) just disconnect the brown wire, set timing and reconnect. Everyone, including me, will tell you to then remove the ECM fuse to "reset" the ECM but I was told by a GM tech that that was unnecessary. Note: It's difficult but be sure the dist hold-down is actually up on the dist when you tighten the bolt. I found mine completely off the dist.
