Setting the timing with DM?
Falco
Jesse,
I'm not quite sure what you mean, but there is one thing I can think of. If you don't want to unplug your timing bypass connector fo some reason, you still might check your timing with the help of DM and an adjustable timing light. Just set the value you see in DM as sparking advance on the timing light, so this way you can compensate it. This way you are still looking for 0* advance on the mark.
HTH,
Hu Ryde
I was just trying to see if there was a difference in 0* timing on the pully and what the actual computer see's. I think the pulley that has the timing marks has slipped and is not really 0* when it's set with the gun. I could always do a TDC check which is the truest way but just courious to what DM would say.
Hu Ryde
Perfect, thanks! Good thing I bought a timing light with the adjustment knob!
For those with alot of knock retard or poor idle or sluggish response or too
much time... Check for a spun balancer. Here's an easy way to do it. Set
the timing by the manual, 0 degrees, connector unplugged, etc... After the
timing is set to factory specs, plug in the connector again. Get yourself a
timing light with an adjustable advance knob. Either through diacom, or
another program, or your chip vendor, etc., determine what your timing
advance at idle should be. Most seem to be around 22 - 24 degrees. With
the light advanced to what your timing at idle should be, recheck your
timing, it should read 0 degrees or very close. If you have done it
correctly, you should now know if your balancer is off... If the outer hub
of the balancer is spun, your timing mark will also be off, resulting in
advanced or retarded timing when you set it according to the manual. As a temporary fix if you have a spun balancer, with the advance set properly on the light, adjust the distributor until the balancer shows 0 degrees again. That will get your timing very close, until you get a new balancer.
Hu Ryde
Not sure exactly what the differences are in the chip but if you have datamaster you can determine the value by looking at the spark advance value cell. That will give you what your computer has advanced your timing to.
Ian Turgeon
Cascading Inspiration
maybe im thick headed, but if you set it to a certain advance mechanically, then check it again when the computer adds advance, wouldnt you come up with the same thing without the computer?
thinking:
set at 0 idle, tan disconnect
connect tan wire, hook up dm, look for the advance.
then hook up the gun, adjust to the advance, its going to read right because the computer doesnt know how much mechanical advance or retard you set it at., it just adds 22 to that, so whatever you set it at, add the advance and it will read correct.
not working out in my head (1:45am) ?
CLONE
You would come up with the same thing unless the balancer is spun. In which case it will not read 0 with the computer advance added in. At that point, you adjust the distributor until the balancer is at 0. It's a temporary fix until you do a good TDC check and/or replace the balancer.
Tydriver
TurboLS6 Powa'
CLONE said:
http://www.syty.org/archives/syty/0010/msg00376.html
Thanks Josh, this link is an :eek: EXCELLENT :eek: idea...
Peeps, theres alot of good information in the archives ! This is a stellar example of whats there !
JoeLutz
thinking:
I agree with you Ian. if you set the initial timing so that the mark lines up then hook up the wire and use the knob on the light to turn it back the same amount DM says the ecm is advancing the timing, then the timing marks should line back up. THat just means you've brought it back where it was. But if the damper has sliped, then you are still off by whatever amount the mark is off to begin with.
I do agree this is a good way to see if your actual advance is what the ecm is telling it to advance.
