Perfect, thanks! Good thing I bought a timing light with the adjustment knob!
For those with alot of knock retard or poor idle or sluggish response or too
much time... Check for a spun balancer. Here's an easy way to do it. Set
the timing by the manual, 0 degrees, connector unplugged, etc... After the
timing is set to factory specs, plug in the connector again. Get yourself a
timing light with an adjustable advance knob. Either through diacom, or
another program, or your chip vendor, etc., determine what your timing
advance at idle should be. Most seem to be around 22 - 24 degrees. With
the light advanced to what your timing at idle should be, recheck your
timing, it should read 0 degrees or very close. If you have done it
correctly, you should now know if your balancer is off... If the outer hub
of the balancer is spun, your timing mark will also be off, resulting in
advanced or retarded timing when you set it according to the manual. As a temporary fix if you have a spun balancer, with the advance set properly on the light, adjust the distributor until the balancer shows 0 degrees again. That will get your timing very close, until you get a new balancer.
