You can have someone hold a pencil in #1, turn slowly clockwise until it stops. Make a mark on the harmonic balancer. Then turn it CCW, till it stops, make another mark.
Half way between your two marks is TDC. Make a good visible mark. With the tan wire unplugged, put a timing light on it. Then turn the distributor cap while engine is running to set it at mark. Its fun to hold the timing light, and turning the dist cap, then trying to tighten the bolt that holds the dist cap in place without loosing your mark.
Have fun
Scott
