Loeryder said:Set Your Timing
Disconnect Tan/black wire under passenger side carpeting
Connect itming light to battery and #1 plug wire
Loosen Distributor hold down bolt
Start engine
Set timing to zero by twisting distributor while shining timing light on dampener
Turn off engine
Tighten lockdown bolt
Reconnect tan/black wire and pull ECM fuses for a few minutes to reset ECM
