Sheet metals valve cover vent / PCV
SEL777
One of 101
So, I did not find any answers in my search. My question is what are you guys with sheet metal covers doing for venting or you PCV. I could add a tube and use a clamp on filter, but do not want that burned oil smell or leaks. I know I could avoid that by using a remote catch can with filter, but then what about using the PCV? I was thinking of just drilling a hole to mount the stocker PCV grommet, but wanted some opinions, before I cut the things of beauty up. For the other side I already have the RPM oil fill & bung going on the drivers side. If you'd like to share some pix, that'd be helpful. As always any input would be greatly appreciated.
TIA
TYHOGG
Re: Sheet metals valve cover vent / PVC
PCV junior, lol. I would still consider using some kind of catch can brother. Under boost the pcv doesn't keep the oil mist in the gases from guming up your intake. Just my $.02
I picked up a moroso breather tank for under $100 and have that routed off the drivers side valve cover, and a normal sytle flow through catch can for the passanger so the pcv system still works properly.
GM TURBO
Sell Out
images
SEL777
One of 101
Adam, youz got a pic or two? Did to add a bung for AN fittings, or a short tube and clamp?
SEL777
One of 101
I'll have to fix that....Thanks Dave, I only typed it wrong 4 times.
FIXED
Icarus-54
Donating Old Member
Re: Sheet metals valve cover vent / PCV
I run a breather in the drivers side and a line from the pass. side to an oil seperator(jeg's #555-52205)with both pvc valves on top runnig one to the air cleaner and the other to the tb.That way you keep the vacum and dont get any crap in your intake.
Jack
TYHOGG
I don't have a pic handy, have half the motor disassembled trying to find the blow by. Yes i did use a bung and -an fittings.
SEL777
One of 101
Jack
Jack, you have some pics? So, A short tube and then a clamp filter, then an AN bung and line running to the seperator? Thanks for the P/N. I'll check it out tonight.
Icarus-54
Donating Old Member
I'm not very good with the computer,but tomorrow I'll take some pics and try to e-mail them to you.This system works extremely well,you get no crap at all in the intake and every so often you drain the bottle on the seperator.I've been running this set up for a few years now and when I tore down the engine last fall I was suprised how clean the inside was.
Jack
SEL777
One of 101
Jack
Cool, I look forward to your pix.
SEL777
One of 101
thanks for the pics, no one else has any photos I could see?
SEL777
One of 101
So, no one else want's to share some pix? Only Icaurus sent me pix of his set up w/a filter on the D.Side, and a line running to the air/oil seperator (& 2 out to the PVC'S). My concern w/the filter is leaks/smelly burnt oil fumes leaking into the cabin. I like the thought of 2 -6 lines out the backside of each cover, but do I really need 2? Since the stock set up is oil fill and only a PCV grommet on the other side. Any help as always is appreciated.
TIA
Icarus-54
Donating Old Member
drivers side is for air in,pas side you have 2,one to the tb the other to the air cleaner.Under boost it sucks from the air cleaner,without boost to the throttle body.There are no leaks or smelly fumes
