Shes back
turbotyphoon69
hey ladies, finally got the truck back on the road. I guide waterfowl so I didnt touch it at all during hunting season and started working on it in late Feb. So she hadn't been driven since October of last year until this morning!
Here is what I did:
New up lower ball joints
inner outer tie rods with sleeves
pst poly graphite every thing front and back (frame bushings SUCK!)
stripped all the A arms and frame rails, sanded and undercoated
painted A arms and other suspension parts
solid motor tie down
new plugs and wires
RPM egr delete
new rag less steering shaft
new idler and pitman
Battle Bars
new bump stops
Bell tech Rear Sway bar
Battery relocation to the back (Taylor aluminum box)
kill switch for NHRA
Volvo fan kit with hayden relay and Permacool control box
Starter click fix (Fraud solenoid)
A/C delete almost complete
flushed brake lines
ABS delete
Ditched fender wells
Cruise control delete
and I am sure there are little things I forgot!
Next up: DOMINATE mike at his BBQ :)
coil over kit (being tested)
Epix style a2a (a week or two)
hks BOV (needs install)
rear Disks
and Turn up the boost.
NOTE: Just wanted to say thanks to Mirrado for actually pulling through with the fan kit!
and here she is comming off the lift.....
i had pictures of the sweet underside but my dumb buddy deleted them.
Dusty as hell on the way to the alignment shop!
TYTILIDIE
METH HEAD
Re: Shes back
The only thing you'll be dominating is your friggin hand son. And I dont call you son cause you shine, I call you son cause you're MINE bitch.
wantingasy
Re: Shes back
Did you get rearended? Or is the back bumper misaligned? Could be a bad angle. Looking good! Wish I had a lift! :tup:
