shes breaking up captain
jwaller
Evil Genius/SyTy Guru
shes breaking up captain. what do I do? for those of you who dont know. I am running vortec heads. now the question is. I have a problem with breaking up under boost. I am using NGK TR5 plugs. Now with fresh plugs, she is fine for about 30 min. then it begins to happen. ONLY under boost. I have also tried TR5's and R44LTS's they all act the same way. ~ 30 min use then only past 10psi the break up begins. It only seems to be in 1 cylinder though. I have traced it down to the #3. for the newbies its not a cap and rotor problem!!! 8)
Sy#26
Check your plug wires - I had the same problem a few months ago, was the wires. Make sure routing is ok. Check them two ways - resistance end to end - resistance should be proportional to length. THEN - get a bowl of water, add a little salt - to make it conduct. Hook your ohmmeter to the metal contact on one end of the wire, the other ohmmeter lead goes into the water. Dip the plug wire (in a loop & not the other end) into the water - there should be NO indication of current flow. Your'e trying to see if ANY current flows through the insulation.
My misfire @ high boost blew the head gasket on #6 cylinder - was LOUD!
Barry
Sy#26 (dead again)
Bangor, MI
myclone
"Dammit, Jim Im just a doctor not a mechanic!!!"
Sorry.. Lousy Treck humor there.. :roll:
IMO you have a weak spark in that one cyl if you have narrowed it down to just that one being the prob OR that one cyls plug is getting fouled either by fuel or oil. Spark is poss getting "blown out" due to cyl pressure if its weak. Is it "popping" back through the intake (lean misfire)?
Have you checked/done the following?:
Swapped plugs in that one cyl and how many times?
Swapped out that plug wire?
That one cylinders injector going lean or over rich for some reason?
How did you narrow it down to the one cyl being the prob? Reading plugs or do you have some kinda NASA/aviator/fly boy/MIB data logging program?
(insert Spock voice here>)Need more details to give you a logical hypothesis on the incorrect operation of this internal combustion power generation system.
manitoufs
If you have got a spare $89.00, buy an infrared thermometer from Grainger. Use it to check your header temps. you should see a differential after a hot run. That will help to confirm the cylinder.
And it's a great tool for the troubleshooting arsenal.
smeagol
Ryan bought one of the IR guns. It's badass, very useful.
Did you switch injector plugs around like I said John?
jwaller
I tried swaping the injector plugs around, nothing changed :eek: since going from the TR6 to the TR5, all the cylinders now have the same "look" on the plug. color is even between the cylinders. I ohmed all the wires and got the correct results depending on length. I narowed it down to the # 3 by only changing just that plug and when I only changed that plug the misfire stopped for a short while but will return within the 30min or so. I am going to try chagning #3 wire today. maybe the wire is causing it. I assumed it was the plug BC when I changed the plug the misfire stopped.
"I love it when a plan comes together"
jwaller
the truck is fixed!!!! :p for now. I reinstalled the old plug but regapped it to 25 thou instead of 32. but I also changed the plug wire on the cyl. so your guess is as good as mine. was it the wire or the gap. guess we'll never know. :eek:
jwaller
spoke too soon. the 30min rule kicked in and its back to running like crap past 10psi. what the fuck is wrong with this truck???????
:evil: :evil: :evil:
myclone
Hmm.. All plugs look the same every time?? Even the suspect #3?
That kinda rules out(IMO):
lean misfire
oil/fuel fouled plug
Makes me want to look at ign from the wire back. Have you swapped the following with any luck?:
cap
module
rotor
coil
coil wire
How bout temprature related. If you do a plug swap while the eng is at operating temp is the miss there immediately or does it take another 30 min to show up again? Temp could be opening up a intake leak or poss breaking down one of the ign components. Gotta find a certain set of circumstances that changes the frequency of the misfire happening and go from there. Just throwing ideas/thoughts at ya. :)
ParTyBoy
bad karma catching up?? :wink:
jwaller
thanks for the help dave. And yes all the plugs look the same. there is no evidence of any type of contamination. the motor is brnd new too so there shouldnt be anything like that going on. I will be doing some more testing today. and it didnt seem to matter if I changed the plugs hot or cold. it takes ~ 30 min either way.
ParTyBoy
Last I remember, is that a couple years ago some people were having similar problems like yourself with ignition breakup under high boost..
problem ended being the coil I believe... or distributor...
check the archives....
jwaller
found the problem while at nats. didnt have enough advance in the chip. 10+ deg later and dropped 1.5 seconds off my ET....
