Shredded another belt
DRUNK411
Ok guys I thought I fixed the problem the other day but my Ty shreaded another serpintine belt. I yanked the belt and checked all the pully's they all spin freely and there are not any large burs or shape parts I could feel on any othe them. Now im stumped, I am running all the stock pullies except I have a polished march pully on my alternator, because the alternator was polished also. Any other ideas I included a few pics I know its kind of hard to tell by pics but maybe someone can pick up on something I am missing out on. It almost looks like the alternator is back to far to me but I dont know how that could be possible I think I got it back in there right.
MikeRenz
not stock
Re: Shreaded another belt
i'd be willing to bet its the alt pulley. slap the stocker back on.
DRUNK411
Does it matter if it just the one pulley? Aren't there guys running March pully's on there trucks with now problem? Or do I need to run the whole set?
MikeRenz
not stock
maybe the spacing it slightly different?
how are your belts shredding? are the ribs cutting off? Or is the belt just cutting in half?
DRUNK411
It is cutting like one or two ribs off the belt in the front closest to the fan.
wheels
I dont know if you have solid mounts or a tie-down, but make sure nothing is hitting the belt when the engine is torqued. It can move quite a bit.
MikeRenz
not stock
spacing of your pulleys is probably just off by a little...that or the grooves on one of the pulleys is chewed. :dunno:
if you have the stock alt pulley...try that
DRUNK411
I do have the stock pulley I will try that when I finish installing my shocks that was my next project try to figure out what is going on with the belt. I do have solid mounts on the truck also so I dont think the engins is shifting anywhere. Thanks for the help so far guys.
SY2932
Administrator
If you have a mechanics stethoscope listening to each of the pulleys with the truck running will help you narrow down which one it is. Sometimes when a bearing goes out, it won't be noticeable with no load on it. It will spin freely by hand. However when it's under a load, it will bind up. There is some serious tension on those pulleys with the belt installed...
If you have had the PS pulley off, make sure that it's fully seated.
SY2455
70's Veteran
I would do this. When I was having this problem about 12 years ago on a different truck it turn out that the tensioning pulley / set was fatigue and not keeping the correct amount of tension on the belt.
When you change your alternator pully, Did you keep the spacer that fits between the pulley and the fan ? It's not very big, so it is easy to over look, it like 1/8" to > 1/4" thick.
Ry368
one mile = 5280 feet
I have all March pullies on mine with NO issues what so ever.......does your tentioner pulley spin freely? Remove and inspect the entire tentioner and pulley to see if the bearings are done.
DRUNK411
Re: Shredded another belt
There are a bunch of black marks and scuffs on the alt pulley so I am going to pull that off and see if the spacer is in there and if not see if I can find one or put the stock pulley back on. Thanks for the help guys.
TY0618
I had this poblem with my '84 V8 jimmy. For me, my p/s pump was worn. Back and forth play + or - 1/4 inch=okay. more than that it could be your problem.
