Shur Flo IC pump location Q's
0966Sy
Code what?
Does the Stock IC pump location sit level with the feed to the pump for flow purposes? Would it be possible to mount a shur flow pump above the lower cche without stopping flow or slowing it down the flow of the pump? Do the IC pumps work under vacume also?
Erik
MadPSI
Not that it would help, but for informational purposes...
I mounted my ShurFlo pump on the passenger side fender well just below the water resevior and it seemed to work great. If you've got it hotwired you can fill the IC while it's on. This eliminates any trapped air in the system.
keith455
Average Joe
Staff member
I mounted mine in the stock location.
Got this from http://www.sytyarchives.com/howto/viewarticle.php?article_name=ic_hose_and_pump.php&dir=engine
I also just did a Jabsco on a truck this weekend and I plan on putting pictures up ASAP.
EightSecV6
You can mount it using the bracket that comes with it and put it in the stock location using the stock inlet 90deg hose. Use a transmission cooler mounting kit and attach it directly to the heat exchanger. They are available at most parts stores, includes 4 small pieces of foam, 4 long pins that push through the core and 4 self locking type clips that push on the long pins you push through the core. This also eliminates the sharp turn on the discharge you have to make when using a jabsco pump. You will have to cut the stock mounting bracket off.
Look at the pic posted by sy2173 above, rotate the pump CCW 90 deg, and also rotate the suction hose (small black hose) 90 deg CCW as well, the discharge will come straight out the side and if you desire, you can cut about 1" off the factory ruber hose that went to the old pump and attach it you can do this whole job in less than a half hour including wiring.
Bill Anderson
