Shurflo Intercooler Pump
Typhoonracer
Old Guard GURU
Re: Shurflo Intercooler Pump
That is the same pump that you got with the 45K upgrade from ATR years back...
I had one on my truck for a few years. Flows almost to much water... Finding a good mounting spot is the biggy. You should concider getting the Hayden oil cooler to increase your water capacity as well.
I think PEP Boys still has them for around $100.
critical
meltdown
3.5 GPM seems a little high for the stock ic system. The coolant will circulate too fast. Remember that the fluid needs time to "soak" up the heat in the intercooler, as well as dissipate the heat through the radiator. I have the sure-flo 2.8 gpm and it may be a little too fast still. I added an oil cooler in line w/the ic radiator to gain more surface area. That works well so far.
SYO237
SyTy Registry
I have a used one for sale if you want..... still worked great when I took it off the truck.
$40 shipped.
vortecfiero
from what ive read on other boards... you cant flow too much water...within reason of course.
there are a lot of guys using 15 gal/min pumps with small oil cooler exchangers and 1/2 to 3/4 in hoses
