make sure valve is completely closed(whether it be tdc on that cylinder, or the oposing spring is down), find the point where pushrod starts to feel tention, turn nut 1/2 turn. If you have poly locks you will want to turn the allen down to firm up the pushrod, then at the same time tighten the screw/nut. repeat as necessary.
