Situation no fixed. ECM looses voltage
Sorry, but this is a new post because I need some help with this. Old thread = I thought I fixed it but nope.
I put the Sy back on its feet fired her up and crap. Situation is now worse. (On the jacks for about 2 months as I re-bushed the front a-arms.) On initial startup (laptop not yet on as this was not expected) it really ran like crap. Almost not at all, died a few times, had to keep giving it throttle. I get the laptop running and of course it settles down a bit and goes in to what it was doing last year.
Here are two DM's. Specifically please look at 257, records 907-917 and 1136-1324
Notice how the voltage drops to -0- and then almost slowly returns. What the heck is causing this???
http://www.sonic.net/~donpris/DM%20files/AutoLog_256.uni
http://www.sonic.net/~donpris/DM%20files/AutoLog_257.uni
Code MALF42 also set
Meantime..
I'm physically removing all the grounds and re-setting them. That means each little ground wire at the ECM and the grounds at the motor. ECM still looses power ever so briefly which resets everything causing the crazy running. It may be a bad ECM. I do have a code MALF42. Supposed to be not related but people have changed their dist and had good luck. I have another dist so will try that.
I also intend to remove the ECM from its case and run the truck that way to see if I can cause this issue. I hope I don't need a new ECM but if someone has a known good one LMK.
I need to actually make this problem happen (instead of just watching it happen) so I can really fix it.
So thanks all!
Daryl H
Re: Situation no fixed. ECM looses voltage
Did you ever get around to doing the voltage mod for the ECM or running a temporary power wire?
What is the battery voltage with key on and not running per DM?
The Bronze
Driveability: Look at your Baro on these last two DM records. They are showing ~57kpa. That's almost half of what it is suppose to be. Your engine used to make ~100kpa on your 227 recording. You need to check your MAP sensor, wiring and vacuum connections. If they are all good, you need to check the rest of your vacuum lines. Then use a meter to see what the voltages are at the 3 wires. You should have 5V, ~4.5V and 0.0xV at those wires. No guessing, just the readings. The MAP voltage is likely responsible for keeping your IAC counts way up, your idle high and various other driveability issues. The MAP is the load sensor and has WAY more priority than most other sensors.
Hiccup: To be honest, I stayed out of your last thread. I usually love to chime in on these, but the tone of the thread was to look at things and not put a meter on them. To chase this down, it would be most beneficial to be looking at things that will cause the computer to reset. Your 256 file shows a computer reset, the 257 file looks like there might have been one, but the PCM resumed the count. Personally, I would ignore the data that was present at the time of the hiccups. You need to be watching A6 (Ignition switched voltage), B1 and C16 (Constant hot) and the grounds (D1, A12 and B12). The other grounds will cause driveability issues, but not a reset. If this was me and I didn't have 6 channels of scope available to record, I would get a couple of meters, put them on min/max and get it to act up. Look for the voltage to drop or the grounds to abruptly gain voltage. You will then be able to trace the problem to it's source, or rule out inputs and blame the PCM.
Edit: Just to be sure it isn't lost in translation- stop looking at the DM values during the reset to diagnose it. Those values may or may not lead you astray.
I have not done the voltage mod.
Bronze, I will print your reply and do everything you suggest and reply. Since I'm actually putting hands on my grounds and power wires it will be this afternoon (truck and this computer at 2 different places). I appreciate your input.
Well you guys are gonna think I'm nuts and I will not blame you. But I think I actually fixed this thing. After hooking up all the stuff I had disconnected I took the chip board (Moats Bank Switching Adapter) out of the ECM and reset the chips. Now this board come with a remote:
http://www.moates.net/ex-remote-switch-wled-p-47.html?cPath=31
Just for the heck of it I left it disconnected. Fired the truck and it runs fine. I can't believe it so I connect the remote and truck acts up. Disconnect again, runs fine.
This is crazy, must be something haywire with the remote or its cable. I will look into that later. Might email Moats. Anyhow, I just drove the truck home, roughly 8 miles, ran fine the whole way.
I suppose you should take the above with a large helping of salt. I thought I had it fixed last fall also. If it changes I'll let you know but for now I think I've got it.
I really appreciate the detailed replies. :tup:They are printed and are now filed for future ref.
