SLIGHT KNOCK?
When I first start my truck it smokes, but when I hit the gas it doesn't. It knocks until it warms up, but then it stops. The torque convertor is tight. The lower it idles, the more it knocks, but when you give it gas, the knock goes away. When I build up boost it doesn't knock, it only knocks when it idles. Any ideas?
sytydvr
what chip does it have... my typhoon had the same problem. As soon as I got rid of the engine blowing kenne bell chip and put the stock one back on the problem went away. good thing I was easy on it with the kenne bell chip if not bye bye engine
well hope that helps you can get the stock chip at gmpartsdirect for about 40bucks
lSyclonel
its sounds like bad valve guides when you start it up and smoke. and when it knocks when its cold, mine had that too it did it for about 3-4 mins. i was told it was a problem with gm, and they called it a cold engine knock.
hope it helps
TyMeUp
Before you do anything, first pull the serpentine belt and start the cold engine ... just to make sure that the smoke and the noise are related.
If you suspect the valve guides, try the suggested 'Timing Light Test' to distinguish between valve train and lower end noise. I've used this before to ID a worn rocker arm and it really works.
"Diagnose Noises with a timing light?
Valve train noises occur at half of crankshaft speed so even if your ear can't tell whether the noise is happening at 700 rpm (raps per minute) or only 350 rpm, your eyes can. Hook the timing light to any one cylinder and watch the flash illuminate the timing mark. Stare at it for a while and see if the flash jives with the knock. If it does, then it is more likely to be rocker arms, pushrods, lifters, camshaft, cam bearings, timing chain and gears. If the noise seems twice as fast it is probably in the crank, mains, rods, rod bearings, wristpins and pistons."
Also, from the next page (Engine Noise Diagnosis 102) of the original link:
http://www.remanufactured-engines.com/page5.htm
"When the engine is cold, the aluminum piston is small in comparison to it's iron cylinder. Therefore the rather hollow slapping noise will be loudest first thing in the morning. After the engine warms up, the aluminum piston heats up faster than it's iron cylinder, cutting down on the excessive clearance between the piston and cylinder wall."
sytydvr
oh other than the smoking mine didnt smoke.
sounds likes valve guides how many miles does it have?
sytydvr
wow thats not many miles... maybe theres a leak somewhere maybe turbo ..... what color is the smoke is it white or dark?
