Re: Slight ping at partial throttle
Problem is no datamaster yet and WB02 hasn't read right in a while
http://www.syty.net/forums/showthread.php?t=102511. Set the timing at 0 however the actual timing indicator is worn so just bumped it to the arrow assuming that was the mark. Took it for a drive after and it was better but still had slight pinging. It's never really under boost or WOT only partial throttle. Running Dig's chip.
Always run 92 or better gas. No alky. Stock ported turbo, external gate, cat delete, 160tstat, AFPR, walbro255, 60lb injectors, 3 bar map, L35s, custom ground cam, egr delete, IC pump, forged internals,4 bolt mains.
New replacement coil and TPS as of yesterday. New(er) distributor pick up coil.
Haven't replaced plug wires/plugs in a little while. Starting to think that could be contributing because under WOT pinging is gone but it has slight flutter only in high gear. Bosch WB sensor is on it's way so hopefully I'm not in the dark anymore with A/F assuming the current sensor I have in is bad.
