Slight Stumble
txshark44
Anyone have any advise. My truck has a slight stumble on light accel and cruising speeds. No miss when your on it hard. New plugs, wires, cap and rotor. Flushed fuel injectors.
Flyin Ryan
hated cuz he drives fords
Re: Slight Stumble
aside from what was mentioned above i'd also make sure your egr and o2 are functioning correctly as well... any check engine lights?
jimmyz79
Re-Member
Re: Slight Stumble
Same here. All new wires, plugs, cap, rotor, vac lines. no check engine light.
Its kind of annoying. Guess I'll start replacing sensors.
Can a TPS be bad and not log a code?
txshark44
Re: Slight Stumble
put a Tps in already because truck was dying when accell that took car of that but still misfire. No codes. Throttle Body shaft leak ??????? sound possible because I seem to loose vacum to AC every now and then
supersports10
Re: Slight Stumble
bam!!! right there....you answered your own question,,, you have a vac leak,...check ALL of the lines.
