slow crank? alternator, starter?
cvcsmkr
ok about a week ago i replaced battery with optima red top. it started up great the first time then every time after that it would get worse and worse. it would take almost 10 seconds before it would turn over.
well it turns out i had to put battery back in engine bay. so i went with the Odyssey 925. same exact problem i am getting a slow crank, but the first start-up was great voltage was high, and turned right over. but now after about 6 turnovers it takes 8 sec's or so to turn on. i was also going thru a DM file i did on 6/20 and my WOT volts were @ 12.1.
is my altenator bad?
GM TURBO
Sell Out
I've generally related slow starts to fuel issues - i.e. fuel pump and/or fuel filter.
Does it crank slow or just take a long time? If it cranks at the normal speed I'd say the electrical system is good.
cvcsmkr
both, since its cranking so slow, its take a long time. its not as if the truck cranks fine and just takes 5 secs or so. it acutually cranks like its in slow motion.
tytom
Battery voltage ? Connections? Cables? If they check out fine then its prob the starter starting to go and taking up too much juice. (brushes ?) Or, unlikely tho, Your timing could be off. This is all I can think of.
ItsMyTy
Life is beter at 25 PSI
take a meter and see what your voltage is at idle
you should be above 13 volts
if not you need an alternator
