HighPerformanceTrucks
Lift & Shift Specialist
Recently I've been have a problem with my TE-44 spooling up slow. It reaches full boost, but the boost climbs sort of gradually not quickly as normal. The motor starts breaking up when load increases.
I've checked out some things to rule out possible problems.
- Turbine wheel blades are not damaged and there is no shaft play.
- All compressor hose connections do not leak
- Blow off valve not leaking
- Fuel pressure is set correctly
- Air filter is clean and not obstructed
- Vacuum lines to boost control solenoid and wastegate appear to be connected tightly
- No codes
- Changed cap/rotor, plugs and 02 sensor (previous parts were in great condition)
If this doesn't fix it, then I'm guessing possibly the boost control solenoid is going bad or the ECM and or/ Ultimate Chip? Feels like every setting is in valet mode. I ruled out the boost command as the problem because the problem persists even when the boost command is turned off.
Any ideas I haven't thought of?
Adam Auerbach
Sy #2419
- No codes
Adam Auerbach
Sy #2419
