hellcat1
I tried doing a quick search for this issue before I posted, but didn't find any hits. Sorry if this has already been asked.
I noticed the other day when I got back home from the fire station, that my 94 Bravada was not exactly where I had parked it. It was about 3 foot back from where I had parked it to work on the A/C system. I asked my wife and son if they had moved it, and both said that they had not touched it. Brow furrowed, I went about my daily activities because it was 110+F in the driveway, and I have the radiator and accessories pulled out for repairs, so It didn't get investigated any further. I live in Houston, so my driveway is fairly flat. I went back to the station the following morning for my 24hr shift then back home the following morning and found the Bravada another 3 foot down the driveway. Since I had the only set of keys to it in my pocket, I didn't even have to ask if they touched it. I put a rock behind the tire and went it to shower and change. When I came out to check it, it was already backed against the rock with enough pressure that I couldn't move it.
So, my Bravada was making a run for it like a 3 toed sloth. It has 175k miles and everything in and under it look stock. The front driveshaft was removed by the previous owner and is M.I.A./K.I.A. I will try and do the DaveP test tomorrow when I get home (after 96hrs of being at the station due to Hurricane Harvey, I need some garage therapy). I'm most likely going to find that the viscous coupling has failed open, but in the event that it hasn't, does anybody have any other ideas on what may be wrong?
I was planning on pulling it and the 4L60e to do a 4L80e swap anyway, if Aaron Timm can get a 32 spline input shaft GP going. I've already confirmed with him that my swap is contingent on that input shaft.
