small bit of help please.
Wikid 1
200+ lbs of puppy!
I'm going to order my Osterich, and tunerpro RT tonight, i was going to email moates but it's after hours and i'd like to order this tonight. Is there anything else i'll need to order, such as chip adapters etc etc to make this work?
sorry for the simple question but i know i can get an answer tonight from you guys :tup:
Thanks!
Wikid 1
200+ lbs of puppy!
Re: small bit of help please.
Okay, well I ordered the shiznit! can't wait on an answer all day :D should be here in 3 days. :tup:
SBNova
I think you'll want a zif and a G1 adapter if its anything like my Autoprom. The G1 (I think) will allow you to leave your stock chip in your memcal and not harm anything. The zif is usually needed in the G1, or you can forget the G1 and use the ZIF in your memcal after you pry out the stock chip.
Look into it, then email him and add it to your order.
Wikid 1
200+ lbs of puppy!
I emailed him, it doesn't look like it though, from what i can tell the osterich takes the place of the stock chip, you just flash the stock "chip" image onto the osterich...
dude now your scarin me lol
You need an adapter (moates) to fit between the stock chip and for the osterich to plug into.
SBNova
Yup, I think you need the adapter, or you'll need to unsolder and pry the stock chip off the memcal to put the ostrcih header in- and in my case I still needed a ZIF to help clear the ECM case. Get ahold of Craig, and see if he will alter your order before he sends it out.
Wikid 1
200+ lbs of puppy!
yeah, you'll need the G1 memcal adapter, and the S2 zif socket adapter, :tup:
MRKING
New Parts for Old Trucks
The stock chip must still be connected to the g1when emulating, and the ostrich must get a bin file uploaded from your laptop . If you ONLY have a stock prom and want to make changes in tunerpro , you will need some kind of prom reader to get your stock bin onto your laptop , then you upload it to the ostrich . Get craigs g1 kit , it comes with the g1 , zif , and 2 smaller chips in case you ever want to put the bin on hardware and not just emulate with software .And that would require a chip burner . Have fun . Not everyone will need all that stuff though , it just depends on what you want to do .
