smoke and more smoke
Nasariobv
lately more and more smoke is coimg out of the sy engine, when i start it in the morning lots of white smoke, then when i accelerate i get smoke through the vents, allot of smoke through the crankcase breather.....my stock engine has 113k, has it had it???????
djwaggoner
check compression before u panic...the valve seals are notorious for doing just what u describe. They get hard and crack allowing oil to leak past the valve stem into the combustion chamber. Mine crapped out well before 100k.
They can be changed with the heads on...follow the procedure in the GM manual.
HTH, djw
Lynn D. Brown
White Smoke
White Smoke
RU sure it's "white" smoke ? If it's truly white, uncombusted smoke, the only place I can see that coming from is by having oil leak onto a very hot surface like the exhaust, which then vaporizes it (not combust it).
One classic case where this happens is when U blow the turbo center seal and oil leaks into the exhaust. As usual I know because it happened on my TTA, but most of this huge quantity of truly white smoke came out the back.
Nasariobv
ok
ok
ok it only smokes at startup from the tailpipes (white smoke), when i accelerate i get smoke through the vents (a little but noticeble), i gonna go ahead and replaeced the heads with some L35 i found.....lets see what happens then...
myclone
Re: ok
Re: ok
Not to pee on your parade but I seriously doubt swapping heads is gonna fix it. I dunno how your PCV system is set up or if you have a breather in the valve cover but what youre describing sounds like blow by. The only fix for that is a rebuild.
FYI worn/bad valve seals will not cause smoke to come through the vents only out the exhaust.
skata
is your pcv setup modified? if you are just venting into the atmosphere, hook up a short length of hose and then filter, and run it down low and back in your engine compartment somewhere. that way any smoke/fumes that come out of your engine go down and back. and not in your truck.
also check your rear hood seal, and make sure you have no openings in your firewall.
every engine has some blowby under acceleration. you probably have a little more than normal, but that is expected with the miles you have. excessive blowby comes from worn piston rings. smoke on start-up is usually valve seals or turbo seals.
Nasariobv
hey
hey
hey after some more csi work on the sy engine this is what i have found....
first lots of oil being drip below the turbo.....
two, somehow when i use the stock airbox with the crankcase hose connected to it, i got a oil all inside the intercooler and the turbo inlet.......(sh#t)
three, well there is an excessive amount of blow by smoke coming from the oil filler neck and the crankcase filter.....
looks like i will need an engine rebuild..........with 113k on it and the previous owners abuse the heck out of it, so if anybody have contacts in the so cal area for a good engine rebuilder give the 411 on them....
Nasariobv
sh***t
sh***t
yes it seems my turbo seal is shot also, i will be considering a whole engine i mean everything rebuild.....my payments are only 200 bucks a month, and i have a year left on it......so i should have plenty of time and $$$$ to get it rebuild so i am open to ideas as what kinda rebuild i should go for.....any ideas anybody......
Lynn D. Brown
Engine rebuild
Engine rebuild
Depends on how far ya wanta go ? Daily driver ? Mostly strip, street strip ? Do U care about reliability or street manners ?
Nasariobv
street strip
street strip
mostly a street strip combo, it wont be a daily driver, just a weekend and a strip car....so anybody any ideas......i have a 5k budget???? i was thinking of going with KB parts since he is local to me...
myclone
There are a bunch more ppl that can help you with parts other than KB. You wont find too many ppl on here that have good things to say about his syty stuff so if I were you Id do a search on "KB" or "Kenne Bell" then judge for yourself.
First place Id go after doing the KB search/research is click on the "links" to your upper left. A LOT of reputable vendors and info in there.
Nasariobv
thanks
thanks
thanks for the heads up, im in no hurrry so i will do my homework on everything i could find.....but should i rebuild my block.....or go for a new setup???? what are the pros and cons of using my block or going with a new block...
Nasariobv
thanks again
thanks again
yes i found mike from rpm and i will give him a call monday.....thanks all for the info.........sy106 stock engine RIP 113k miles.........
Nasariobv
decided to
decided to
I have finnaly decided after much thaught to put the sy away anf begin a complete rebuild, engine, tranny, suspension, i mean everything so hopefully by the end of next year it will be done.....wish me luck....
Nasariobv
well
well
well i didnt pay much for the sy when i got it, i knew it had problems, everytime i fix something, another thing happens so instaed of just bs with it, just gonna put it away and do a complete rebuild......so whoever was the previous owner of sy106 *uck you for not taking care of it and what an abuser........
HotRudyRod
Im also havin white smoke....
Im also havin big white smoke clouds at start up and when i take a long hiway drive the tailgate gets covered by this cooked up oil that feels like dust to the touch but has an oily consistency and if i launch it with the boost i'll be able to see a big cloud of smoke on the rear view mirror, I believe it might be a turbo seal cause the power hasnt decreased that much and the engine has only 86ks on it, any sugestions on how can i check the turbo seals or the valve seals in case it wasnt the turbo?
Thanks.
