smoke coming from turbo
cvcsmkr
just put on pte44(which i was told had 4k miles) w/pte downpipe
using stock oil drain with correct flange to rubber then to cut stock drain.
smoke coming from turbo exhaust housing.
after truck is shut off oil come out of exhaust housing and runs down.
also see smoke coming all off downpipe(wrapped) i think is coming out of slip joint.
got this turbo and drain from someone off this board.
i am leaning towards oil drain, but how could he have been running this same drain and not been having this problem??
i swapped the 3-4 bolt housing w/ a syty specific myself, just unscrewed the bolts and put on new, hope there wasnt anything special.
what do you guys think?
jwaller
Evil Genius/SyTy Guru
Re: smoke coming from turbo
remove the DP and check to see if the oil is coming from the turbine shaft seal, if it is then you have a bad turbine shaft seal. the drian line is large enough and I doubt you clogged it up installig your new turbo.
cvcsmkr
it deffinitelly looks like there was oil in the dp.
looks like it was also making is way out of dp slip joint.
is replacing turbo shaft seal something i can do myself?
Lynn D. Brown
Chad - I doubt it. I am a decent mechanic and I wouldn't do it. U would probably need a press I would guess. I think U've blown the seal to the exhaust side. Do U see white smoke out the exhaust (I did it before) ? If it's bluish, then U blew it to the intake side. I'd get a new bigger turbo.
jwaller
any turbo repair shop can do it for you, it's not that you cant do it but it has to go back together "exactly" how it came apart. if it doesnt it will be out of balance.
TurboTony
There is no "seal" on the turbine shaft. There is a ring of sorts that keeps exhaust gas from entering the center of the turbo, but nothing that keeps oil from entering the exhaust side.
The only thing that prevents oil in the turbing housing is gravity. The oil level in the center section must be drained away fast enough or it will spill over into the turbine housing. Make sure that you drain line is an honest 1/2 inch ID everywhere and that there are no restrictions. The turbo must also be mounted so that the feed and drain lines are perpendicular to the ground.
Check all that first before you send your turbo out for a rebuild.
Tony
cvcsmkr
okay i will be mating up a -12 drain line today.
i let you guys know what happens.
if that doesn't fix it, ill probably be hitting you up waller.
TurboTony
10 AN is plenty for a drain line but it is important that all fittings, adapters, etc are at least 1/2 ID. Alot of those sorts of things are -10 fittings but have a 3/8 ID.
I went through all this with my sy back in the day when I ran the 63e.
Tony
cvcsmkr
well i already got the 12.
it looks like it will fit okay.
i didn't want to fool around and have to ream out any of the -10's so i just went w/12.
thanks tony
jwaller
thanks. and yes the turbine shaft seal(metal ring) does does control oil flow. I gues thatts why the brand new turbo(PTE Dual bb) I just installed had a bad one and it was spitting oil. once it was replaced it didnt leak anymore.
