Smoke
NecroWolf
lost marbles member
i'm curious if i finaly broke my motor? i have so much blowby coming out of it i can barely see to drive. i was out crusing it today and it started to cough and spit and all that and lost power. i took it home but it stalled out when i had to slow down to make turn and wouldn't start after that. i looked and the vacum hose had popped off my afpr. so my fuel pressure went to 50lbs while i was crusing. no biggie i figured i fouled out the plugs so i swapped them out and only one was really soaked but it looked oil soaked. truck still starts will some effort, gotta give it gas. but there's just smoke pouring out from all the little seams in the motor, and if you take the oil fill cap off it's like a chimney. so did i break a ring or piston? any guesses? i won't know till i pull it apart after i get back from the desert.
blk00z28
Forced to by choice
Re: Smoke
Do a compression test. You'll see if you broke a ring or if there is a hole in a piston.
My #3 ring is broke and when I come to a stop from just normal driving I smoke like a train too. Comes out of the breather on the drivers side though. ;)
