Smokey at idle new engine
etriebe
I think my rings need to be set in a bit better. What is the best way to do so. I finally got it running decent enough to idle by itself and rev up and not stumble.
1madgumby
Re: Smokey at idle new engine
drive it around for about 200 miles NO BOOST, Vary easy, then change the oil & beat on it. Thats what I did no problum here. If it still smoking put 200 miles more on it, still smoking you have A problum some were, might not be the rings though, could be to much fuel. hope this helps.
gkrcr882
SyTyless......for now!
There are two schools of thought on this: drive it like you stole it, and drive it normally without beating the crap out of it. Variance in engine speed and load is key.
nello
I think my rings need to be set in a bit better. .
I think you'd be right. I would also get close to redline, underload, a couple of times. Let the connecting rods stretch out too.
