U N ME ON 3
Well, I changed my thermostat and didnt drill the holes that people recommend. Fired it up and let it run for a while and then the temp guage goes bezerk. I open the hood and the hose that connects to the thermostat housing is either leaking a little bit or not getting any coolant due to the opening problem. The hose is not tight when squeezed while hot. Shouldnt it be?? Imade sure that I put the correct amount in the radiator/ overflow tank and did exactly what sytyarchives.com says. Whats the next step? Did I botch up the install? hopefully someone can put me in the right direction. SLoclone 1411
