Smoooooke
bezerk
Re: Smoooooke
it can be a bunch of stuff doing that realy.
oil supply line to turbo, oilpressure sendding unit, remote filter housing oillines, dist. gasket. Valve cover seals, blockoffplate for Feulpump if they installed a replacement engine somewhere that needed one.
i also think it's the best to find somebody that has a carlift or so, so you can check it from the bottem.
the baPhoon
Re: Smoooooke
Yeah the lines from the oilfilter were sitting on the flange for the crossover pipe even though they were bolted to the retaining bracket. I moved them and started it up again and it didnt seem like thats where the leak was caused. I guess ill go ahead and yank the chiller and see whats goin on up there.
SY2455
70's Veteran
Re: Smoooooke
Also check your power steering hose. After I fix my oil filter ad. 1 month later I had another leak and it turn out to be my power steering pump going bad, it wasn't making noise yet, but the fluid was dark like engine oil.
the baPhoon
Re: Smoooooke
Ya i think it is my filter adapter. Ive been busy lately and havent gotten much of chance but im gona yank the intercooler today and see what we got.
the baPhoon
Re: Smoooooke
Allright, Ive been rather buisy due to the holiday season and whatnot. Ive finally found time to wrench on the Ty and...
Madpsi wrote..
had an extremely similar problem with oil leaking in that exact area. There is a bracket that holds up the oil cooler lines right next to the power steering pump. The moron that had the truck before neglected to connect it, and the metal oil line rubbed against the crossover pipe, causing a tiny hole to form. The line looked fine, but leaked after the truck warmed up. I had to remove the lower IC and start the truck up on jackstands to find it. I'd double-check those lines...
EXACTLY. I got under there and disconected the lines on both ends and this is what i found..
Ive gotten some fittings and enough steel line to replace the entire section. My question is HOW the hell do i get the lines out of there? Ive disconected them on each end and it seems damn near impossible to yank it out. Any suggestions?
the baPhoon
Re: Smoooooke
Well i ended up just cutting the hoses and running down to lopers to get some steel braided lines. Ill post some pix of the swap up after im done with it.
