SY2455
70's Veteran
Test results, Cold start up to 20.37 minutes run time. Idle only.
In the readings the number in parenthesis are from the reading taken at idle after getting home from the road test. All readings were taken with fuel pressure set at 34lbs after a complete tune up. Fuel press is turned down for a smog test I'll do on Monday 02-27-06. Then fuel press will be back up to 45 lbs.
RPM 725-750
o2 (mv) 117-867
Integratr 135
No codes present
Open/clsd loop Close
Exhaust Oxygen Rich
Block Learn 128
FT Cell 0
A/F Learned NO (YES)
A/F Ratio 14.7
Asynch Pw(ms) 0.4
Base Pw(ms) 1.4
TPS (V) 0.66
Throttle (%) 0
Iac Position 0
Desired Iac 0
Desired Idle 725
Prom ID 3961
Coolant (*F) 165 (195)
Start Clnt (*F) 168 (73)
Map ("HG) 6.4
Map (V) 0.61
Vacuum ("Hg) 23.9 (25.6)
Vacuum (V) 3.77
Baro ("Hg) 27
Baro (V) 4.32
Boost ("Hg) 0.0
Des Boost ("Hg) 0.0
Waste Gate (%) 100
Intercooler Pump ON
Air Flow (gm/sec) 0
Mat (*F) 115
Battery 13.5
Time 20:37
Knock NO
Spark Adv (*) 24
ESC Active NO
Knock Retard 0
EGR Solendid OFF
EGR Duty (%) 0
Des EGR (%) 0.0
Veh Speed (mph) 0
A/C Clutch OFF
A/C Request NO
P/N Switch P-N--
TCC Command P1
Here's the numbers that were taken during the test drive. Cruise control was set at 75 mph. The land covered was relatively flat, there was little to no headwind, and the outside temperature was between 70-75 degrees.
Note that in this list, the number in parenthesis was the number that was shown under medium acceleration and the ranges shown are the lowest and highest numbers seen on the scanner.
RPM 2550
o2 (mv) 62-797
Integratr 128
No codes present
Exhaust Oxygen Learning/Rich
Block Learn 127-132
FT Cell 0
A/F Learned NO/YES
A/F Ratio 14.7 (12.o)
Asynch Pw(ms) 0.5
Base Pw(ms) 2.1-3.1
TPS (V) 0.17-1.23
Throttle (%) 2-20%
Iac Position 7
Desired Iac 7
Desired Idle 625
Prom ID 3961
Coolant (*F) 177-179
Start Clnt (*F) 73
Map ("HG) 10.7-12.5
Map (V) 0.76-1.66
Vacuum ("Hg) 12.9-22.1
Vacuum (V) 1.98-2.95
Baro ("Hg) 27.7
Baro (V) 4.39
Boost ("Hg) 0.0
Des Boost ("Hg) 11.3-13.2
Waste Gate (%) 100
Intercooler Pump ON
Air Flow (gm/sec) 25-27
Mat (*F) 117-158
Battery 13.3-13.8
Time 43.53 (Final time was 80.34)
Knock NO
Spark Adv (*) 24 (15)
ESC Active NO
Knock Retard 0 (6)
EGR Solendid ON
EGR Duty (%) 64-80
Des EGR (%) 0.02-2.7
Veh Speed (mph) 75
A/C Clutch OFF
A/C Request NO
P/N Switch -R-DL
TCC Command PT
It's worth noting that yes... the EGR Duty is 64-80 percent and TCC command was showing a PT (as opposed to a P1) Are those bad readings or do they indicate something being wrong?
Can I get you guys to give your input on the results of these scans? Does everything look good? What needs to be looked into to make the truck more reliable, or prevent problems in the future.
I know I need to look into the Knock Retard. I was wondering if it's related to turning down the fuel pressure for the smog test.
If it's any help, the truck doesn't smoke at all (after changing the valve seals
), it routinely gets 22-25 mpg (if/when I drive it easy
), and there is no perceived consumption of oil (which is better than can be said of the 327 that was in my son's Camaro. He had to add a quart of oil every time he started it.
RPM 725-750
o2 (mv) 117-867
Integratr 135
No codes present
Exhaust Oxygen Rich
Block Learn 128
FT Cell 0
A/F Ratio 14.7
Asynch Pw(ms) 0.4
Base Pw(ms) 1.4
TPS (V) 0.66
Throttle (%) 0
Iac Position 0
Desired Iac 0
Desired Idle 725
Prom ID 3961
Map ("HG) 6.4
Map (V) 0.61
Vacuum (V) 3.77
Baro ("Hg) 27
Baro (V) 4.32
Boost ("Hg) 0.0
Des Boost ("Hg) 0.0
Waste Gate (%) 100
Intercooler Pump ON
Air Flow (gm/sec) 0
Mat (*F) 115
Battery 13.5
Time 20:37
Knock NO
Spark Adv (*) 24
ESC Active NO
Knock Retard 0
EGR Solendid OFF
EGR Duty (%) 0
Des EGR (%) 0.0
Veh Speed (mph) 0
A/C Clutch OFF
A/C Request NO
P/N Switch P-N--
TCC Command P1
RPM 2550
o2 (mv) 62-797
Integratr 128
No codes present
Block Learn 127-132
FT Cell 0
A/F Learned NO/YES
Asynch Pw(ms) 0.5
Base Pw(ms) 2.1-3.1
TPS (V) 0.17-1.23
Throttle (%) 2-20%
Iac Position 7
Desired Iac 7
Desired Idle 625
Prom ID 3961
Start Clnt (*F) 73
Map ("HG) 10.7-12.5
Map (V) 0.76-1.66
Baro ("Hg) 27.7
Baro (V) 4.39
Boost ("Hg) 0.0
Waste Gate (%) 100
Intercooler Pump ON
Mat (*F) 117-158
Battery 13.3-13.8
Knock NO
ESC Active NO
Knock Retard 0 (6)
EGR Solendid ON
EGR Duty (%) 64-80
Veh Speed (mph) 75
A/C Clutch OFF
A/C Request NO
P/N Switch -R-DL
TCC Command PT
