So fed-up with my SY
GT42RSY
Large Turbo
My Sy has not run in a month due to what I thought was a simple ignition wire fix.Turns out,after I replaced the purple wire all the way to the column,replaced the previously burnt 1 guage wire to the battery,a new starter and a new battery,it STILL does NOT run.WTF???After the new battery it started 2 times and then it was the same old thing.It is like a dead short.I have checked all of the connections and they are tight.I don't know what else to do.Any other ideas,other than blowing it up??
nborton
Can you give some more details? I just went through a re-work of all of those components recently and might be able to offer some advice.
Did you replace the alternator?
Once it started those two times, did it stay running until you shut it off?
What do you hear when you turn the key? A click underneath the truck and then nothing, or no click and just nothing, or does the motor start to crank but never completes?
Did you replace the wire from the battery to the starter? and/or when disconnected check the voltage on it?
You can run a 12v wire from the a battery, and tap into the new purple wire you ran, apply voltage and see what it does? If it try's to start, it won't start as you're not powering the accessories, this could indicate that the Park/Neutral safety switch is bad or your key ignition is bad.
GT42RSY
Large Turbo
I did not replace the alternator,Yet!!
Once it started it ran for about 30 min each time before I shut it off.
When I turn the key there is no click,it actually starts to turn over and then stops and tries to turn over very slow like a dead battery or a dead short.
I replaced the wire from the battery to the starter and has good voltage when disconnected.
Also when I turn the key all the lights dim but I have checked and recheck all of the connections.
Thanks for any help
Dewain
ZavzTy547
Senior Member
I'd try a new battery...
I had an Altima battery that went bad after I tried to charged it a few times.
I was getting the same symptoms as you discribed and thougtht it was my starter etc,, I put a new battery in and all is well....
Put in a new battery and if it goes dead, it's your alternator....
gmcturbo
is your problem with just it starting or stalling?
if it dont want to start- many times when the alternator dies, the battery goes with it. have the battery checked, if its dead replace it then check your alternator. if you try to check your alternator, and have a bad battery, it will probably say your alternators dead when it might not be. i see this all the time at work. if both check out ok, i would recheck grounds and the wires.
if its stalling, do a search on "stalling". it will definately give you many ideas. hth
