So here's what I'm thinking.....
sy2206
I want to run four 17x9 C5 Z06 wheels. We all know I will need a 28mm spacer in the rear for the correct offsets. The normal spacers have the 5 holes and 5 studs, where you bolt the spacer on, and bolt the wheel to that. I'm thinking of getting longer wheels studs(like the ones they use on drag cars), and machine a 28mm spacer with just the 5 holes. Slide the spacer on there and let er buck. I could even go back to stock wheels if I wanted, I would just run 4 front wheels, instead of the stock setup(2 fronts, 2 rears). Any see any reason why this wouldn't work? I understand that the further out the wheel is from the point where the stud presses into the axle, it has more leverage for lossening and/or breaking the studs, but if the holes in the spacer and machined so that 28mm thick spacer is pressed on over the studs, I think it would be ok. Thoughts?
jpalmer
Re: So here's what I'm thinking.....
i just recently dealt with this. i was told by the manufacturer that a "adapter" is better, "spacers" are not as strong. two sets of short bolts is better than 1 set of long. I also purchased my "adapters" to be wheel and hub centric. taking some of the pressure off the studs. they were 160 shipped roughly. they wanted precise measurements of wheel and hub with a micrometer.
