the baPhoon
Allright, before i start this im going to let it all out. Its cinco de mayo and im a little sauced.
Ok, yesterday i went ahead and replaced ALL the vac lines on the Ty. I did so because i was getting IAC, EGR and ESC errors on my DM's DTC error code list. After the replacement of all the lines im running NO codes at all. The truck idles a hell of a lot better. The idle is more predictable and doesnt drop below 800, when before i would hit around the 700- mark and it sounded like it wanted to choke out and die. BUT, one of my major problems was low ass boost numbers. After the replacement of the lines i still cant seem to push over the 11 PSI mark. When i say i replaced the vac lines i mean EVERY line. I replaced even the little 1" lines on the damn check valves. I know i did something right because my codes went buh bye. I pulled the intake tube off the stocker turbo and the ends of the impeller are so clean you can eat off them. I dunno if this is stock air-wear or something else but either way i cant make in exess of around 11lbs. When i go from vac to boost i do get a little bit of a fluttering sound from the turbo. I havent as of yet yanked the entire turbo off of the header to look at the complete impeller/propeller fins yet. If yall think i should do this leme know. I would MUCH rather have waller build me up a 20G before shit explodes then buy an entirly new turbo (even though a t76 sounds like a good deal). Yeah, now i do have monies.
Also i have another little issue. Lastnight i was at wal-mart pulling out of a parking spot. I had to go extreme left on the wheel. As i backed out it felt like i drug the tire along the curb. OK. I know when youre thinking, The baFoon is drunk and curb checked his ride. I assure you this wasnt the case. It actually felt like the tire was just being dragged along rather then turning while i backed out. It made an awful noise.
I dont know if this is a related issue but if i try and boost launch number 24 and get above 5PSI i get this loud ass CLUNK CLUNK CLUNK noise under the front end and i can feel a bit of funk under the floorboard..... Upon further inspection it seems that both CV axels are fine. The boots arent ripped and there is very little latteral or horrizontal play when turned with my hand.
Any help would be greatly appriciated. And if any of you phx guys feel up too it, ill have a nice BBQ and some brew for yas if ya feel like cruising out to BFE to take a peek at it with me... Leme know...
