So it begins...Ultimate 50# Questions
bjzq8
Well I put on the Walbro this weekend, and decided to put on the Johnson IC pump too. My audible pinging on full throttle after a few seconds is now gone (it had been present on the original truck...I replaced the dead IC pump, it went away...pump died, came back...with new pump, it's gone again.) I didn't hook up the DM to see what kind of knock counts I was getting, but I could definately feel none of the "held back" feeling I was getting before during pinging. I've got the 50# injectors, AFPR, and ultimate 50# ordered and going to be here soon. My question now is about the Ultimate 50# and the stock turbo (at least until I get the new turbo ordered.)
I have read http://www.chitownsyty.com/bg/chipstuff/50v2.htm, and it seems to say that boost control is now set to either 18 or 21 psi, the reason being the PTE turbo should be run with no boost solenoid (using only the wastegate rod.) So I want to verify with someone that knows...do I need to unplug the solenoid (the wire, not the hose) on my stock turbo as well? It is set to stock length, so I would assume I would get only 10 psi of boost or so. I'm just trying to keep it drivable (it's my "daily") and such while I go through the work of upgrading it. Thank you to anyone that answers, I really appreciate your help! And I am trying to show it by putting my money where my mouth is (and buying from the good guys on the board.)
By the way, the fuel pump install WAS the unshirted hell that everyone said it would be. Perhaps if I were a freakish alien with 8-foot arms and eyes on my fingertips it would have been easier. Doing it at 11 PM in the dark certainly didn't help. But when I got in it and turned the key, it started right up. I am so happy! My eventual goal, after some months, is to outrun my V-8 Fiero. Which, with a slipping clutch, ran 12.0 at 119 mph. On a good day it would probably see 11.5. So I've definately got work to do...and $$$ to blow. Engines too, perhaps...
Bill Jenkins
1992 GMC Typhoon
ZMann
vertically challenged
It's a great feeling accomplishing something on our trucks and having it work ! Been a while since i felt that. ANyways...
My PT52, when installed, had around 15psi of boost..and with the dump tube (plate) off, it would get up around 20 psi. Not sure why, but now i only get 13psi. Sux.
Im curious to how the ultimate 50 does compared to what i have now.
I have a 8-1 now...
Later
Zach Mann
Sy1012
