Less than 6000 miles use. All my other SyTy's have HD propshafts and the way these are built, I don't foresee needing this one. $385 + shipping.
Is that a Gilbert shaft?
Does the shifter bracket or cable need to be modified
to install this HD prop shaft ???![]()
The linkage bracket will need to be changed or modified as it rubs/catches on the HD propshaft. RPM sell the bracket if you don't want to modify the existing.
