Re: Razor Kit, CF driveshaft, BBK TB FS
if the Alky kit is only missing the tank and the low indicator leds/wires for that. i'm calling dibs (inline). still comes with 3 bar map sensor?
Your up, the kit never came with a 3bar map sensor. You can run it with a 2bar also im sure. All its missing is the following that got lost over the years of the truck and parts being moved around.
Two LED lights (on/off and low alky light)
Coolant overflow relocate kit, was a cheap autoparts store kit anyway.
hose from tank to pump (3/8 rubber hose, custom length depending on location of pump anyway)
and the pigtail connector that plugs into the low alky level sensor in the tank. (standard GM 2 pin connector)
you get:
pump
pressure lines from pump
spray nozzle
filter
alky tank with low level sender
controller (never installed)
