solid motor mount question.
BoostedSUV
Re: solid motor mount question.
your such a retard no i was just trying to outsoucre the parts without having to buy a complete kit but i already spoke to turbotime and i am placing an order on one of there kits. nice try tho.
IF YOU ALREADY HAVE THE MOROSO SOLIDS WHY DO YOU NEED THE KIT? you ONLY need the frame pad... just saying
REVEREND HARMON
Party in a box!
REVEREND HARMON
Party in a box!
yes but it those thread dont let me know if the stock pads will bolt up to the moroso mounts as i spent all of last night doing so searching. geez
Its mentioned in many threads that you need custom made frame pads and moroso motor mounts.
http://www.syty.net/forums/showthread.php?t=48497&highlight=moroso+motor+mounts
Plus its kind of common automotive knowledge that solid motor mounts wont bolt up to rubber/stock frame pads. That is probably why people are confused that someone would ask the question.
nallj92
why cant someone make a set of solid motor mounts that are a wide style to fit the stock pads. this would take 90% of the hassle away to swap to solids.
I have not changed mine yet, but on other muscle cars I have owned, I removed the rubber on the drivers mount and welded a piece of steel stock of the same thickness of the rubber on the two halves and reinstalled. It was very easy and the motor will still sit at the same height.
