canadian said:uh, i always thought it was the opposite. if you install solid motor mounts, you DON'T install a soid transmission mount. the solid motor mounts will tie the motor to the frame, but the rubber trans mount will allow some movement of the whole motor/trans assembly. if you did both solids, there's no "give" in the assembly.
