SYO237
SyTy Registry
Re: Solo Question
Most clubs have a novice group that I highly recommend doing a few times. You'll be able to have instructors ride along with you and give you pointers and/or even drive your truck with you in the passenger seat if you so wish. In my local club, if you end up winning the novice class, you get an automatic bump into your real class from that point on since you have proven that you are capable of driving with technique and can be competitive with your class.
If you can, gopro yourself driving. You will learn a ton from it and be able to correct mistakes you see. Find the regulars and ask questions....they usually will be more than happy to lend some tips.
Thanks for all of the responses, the main takeaway for me is spend the time to learn the track and provide feedback to the officials if you feel that there is a risk. Ultimately, if I'm not comfortable I don't have to run.
The AutoX wrecks that I see online must be the minority and due to not following the SCCA guidelines.
This summer should be fun.
