truckins10
Hey guys,
Installed minigaten on crossover, welded integral wastegate shut on turbo, and vac line from turbo port to side port of minigate. I also has a regulator tee'd in on the same line off the turbo and running to the top port of the minigate. During a run you will see boost keep rising in one PSI increments, until it hits about 18-19psi and then the ultimate cuts fuel out. Now I thought it must be the regualtor causing all the problems, so I shut the regulator completely, then what I get it the boost starting at 8psi and running up to 12-13psi by the end of my run. So this sort of told me that the regulators is not the problem. You guys think this is a bad minigate?? Its only been on for 2-3months??
