Ran a good 0-100 run on DM and have a few questions. Truck has a fresh semi-performance motor,jabsco,255hp walbro, afpr(currently at 47lbs),aux. IC, all tune ups done(plugs wires cap rotor fuel filter air filter PCVs,etc)and IC line relocate. I'm still working on my oscillating boost but my plans are to get in the low 12s/high 11s. SMC alky is in the mail. This run was on 91 octane with outside temp around 84F, barometer at 29.3.
In first I launched at 9.9lbs at 2600rpm .5KR and 830mv O2, hitting 915mv by shift.
Not to much else until 2nd- 4325rpm boost tgt 14.3 actual 14.7lbs 14.1deg advance,0KR.BPW at 16.24 with inj. DC at 117. 02s hit 924mv twice before 3rd the lowest at 906mv, staying between 910-920 mostly.
2nd shifted at 4575 with 13.8tgt,14.3actual and WGDC at 80.4 but bpw down to 15.53 because of rpm and inj. DC at 118.4. Am I running out of injector?
My TPS volts are 3.68-3.71v at WOT, probably what's keeping tgt boost at 14.3 instead of 14.7 or so and the battery volts drop to a 3rd gear low of 12.8,bringing the TPS volt down. I'll get the alternator tested today, and will check volts at WOT at the cig. lighter to compare. Any other ideas?
Some 3rd gear #s are 3925 rpm,13.8 tgt, 14.2lbs actual, Lterm 130, Sterm 128, 932mv02, 14.8advance, 0KR, BPW 15.9, inj. DC 104.0 TPS volts 3.67@ 99.2%.
Right afterwards I hit a bump in the road and knock count jumped 200+ and KR hit 4.4deg, previous peaks around 2deg at shifts.
Like I said, alky's on the way and I'm dying to do the ultimate and 3bar but want to fix my WOT voltage first, especially considering the SPAL fan wasn't even on. Anything else interesting here? File's available if you want to see it and I appreciate any help while I learn how to tune this beast before I make it fast.
Jeremy
Jeremy
