Some general maintenence questions...
Baja Resident
I checked the "authority" site, but couldn't find answers to these.
- Anyone know a FRAM part# for the fuel filter on these (93ty)?
- It says just 80w-90 for the differentials, this seems a little odd. Is synthetic 80w-90 better? Is there an additive needed? Aren't these limited slip?
- What size, part# of Optima redtop fits?
- Is there a difference between PST's "polygraphite" front end kit and a "polyurethane" front end kit?
thanks!
Syclone#1992
SyTy.net Moderator
Re: Some general maintenence questions...
Believe they can be found in the booklet at the local autoparts store. http://www.detroitturbo.com/ has them too
Most people don't put synthetic in for transmission fluid, I think for everything else people mainly use synthetic or royal purple.
They should also be able to tell you that at the autoparts store, or once again, I think http://www.detroitturbo.com/ has them
thanks!
Hope this helps.....
sytyguy
Moderated User
Optima Red Top Battery - 8022-091 - $114.99
Wix Fuel Filter - 33481 - $10.99
*We also carry an Exide equivalent to the Optima Red Top (listed below). These are spiral-cell batteries, just like the Optimas, and come with a more flexible warranty. We've sold a few and all customers have been pleased.
Exide Orbital Battery - ORB75DT84 - $99.99
+ $5 manufacturer rebate through 12/31/04
I carry these all day long if you need any. I don't recommend Fram for anything. Well known fact that their filters are sourced-out garbage built by the lowest priced supplier. Not saying this 'cause I sell Wix (buy from me if you like), but just hate to see you put a Fram anything on your truck.
HTHs
Hood
TYRODD
My ass. Look at it.
As far as the differential fluid....
I used royal purple 75W-90, which is synthetic. I was surprised that I could actually tell a difference from using standard oil. Its a bit pricey at $9 a quart, but it is great stuff, just like other royal purple products.
You do not need to add any additives to the royal purple for the limited slip, but you will need to if you decide to go with a standard gear oil(rear-end only).
turbodog
I use synthetic everywhere (oil, front diff, rear diff, ATF in both tranny and T-case). It may not help, but it probably can't hurt either.
As for additive in the rear end, I posted GMC's position on it here:
http://www.syty.net/phpBB2/viewtopic.php?t=38273&start=15
I don't undertsand why everyone on this board says to use it when GM says definitely do NOT use it, and cites the problem it can cause. Is there more recent information that supercedes this TSB?
Baja Resident
to follow up I talked to a local performance shop and they said the difference was urethane tends to squeak while graphite won't make any noises.
myclone
Yeah it will... BTDT
