Some if you please..
juicehead9
93 Typhoon # 0973
OK this may be a little long so stay with me. I just put in alky kit. Mods are PTE 44 turbo, ATR 3in. downpipe, atr 3 in. exhaust, 50 LBS injectors, Phil Long version 4 chip(#2 setteing), etc. I am trying to get it tuned in I have the 10gph nozzle in now Shurflo pump psi is set high. Turbo boost is set at 20psi. FP set at 42psi vac line off. AFR is around12.4 give or take a . something. I get 2-5 KR and boost drops from 20 back down to 14.5-15psi whith it floored. When you get KR does the ECM drop boost as well? I am useing a bleader valve to control boost could it be to big (its an air compreser presure valve with big yellow turn knob) Turn on pont for Aly in at about 4psi. full pump presure at 15psi. I am trying to get it tuned in so I need some pointers what to try next.
unluckyty
Re: Some if you please..
If your using a separate valve for boost control, then the computer can not regulate the wastgate.
I am kinda in the same situation as you are, starting to tune my truck with alky also. I am going to dedicate some time to tuning it tomorrow.
First tuning runs were great, stock turbo with all supporting mods, 100% meth with boost switch activation at 6#, using the ultimate, I was trying for 20# of boost. Truck would only boost15# in first gear, 16# in second, and 17# in third. almost no spark retard at all. boost controlled with a g-valve, very nice steady boost. If i let the computer control the boost was very unsteady and truck was slower on same setting. Best track time was 13.4@99.9 worst was 14.0@98.1.
I have started to work on adjusting the wastgate rod. Now I am getting a more level boost, computer controlled, but alot of spark retard. Also I need a large nozzle for the alky( only have 225 mlpm). My little 4 cylinder Shadow has a 14 gpm nozzle, progressive and it is not too much for it.
Greg
QUICK STORM
B.A.M.F. BMW Tech
juicehead9 said:
Rich it up by fuel or alky?
you want it richer with fuel. i think, i don't know much about alky tuning. mayve one of the experts will chime in
juicehead9
93 Typhoon # 0973
OK Like I said FP is set to 42 with vac line off right now. Can I just go up a few points for fuel on the chip ie. from setting 2 say to 6 (Phil Long chip) or go to say 44 on the AFPR?
