Could be alot of things.
low compression at cilinder, (compression test)
turbo needs rebuild, (feel for clearance at the axle)
valves, (when do the the compression test, and finding a low pressure cilinder, squirt oil above the cilinder, so the rings will shut out blow by, and see if you get good compression, if it ain''t you have a bad valve)
