truckins10
Im alittle confused on the ultimate setup with an external wastegate. Ive done some searching and cam up with it could work. My understanding is that if you use the ultimate(stock injector,motor) you would usually keep the integral wastegate. But everyone has said that the factory wastegate cant control boost well above 15psi, and boost fluctuates, so this is why everyone turns to a bigger external wastegate. Do I have this right?? I was planning on getting the ultimate this winter, but also wanted to get the external for better boost control, so I dont know what to do now?? For guys running an external with a bleeder valve setup, how do you run more than 15ps1 without the ECM setting an overboost code and shutting down??? Much appreciated if someone could help me understand this. Thanks Fern Sy#477
