Spa boost guage mounting
Ty 1450
30psi on 93 oct (boom)
Was reading the install instructions for my spa guage and it says the best spot for mounting the sensor is between the intercooler and inlet manifold. I dont see alot of room for this to be mounted there and wanted to see what other people did for mounting.
TIA
SY2932
Administrator
I don't know if the SPA is any different from other boost gauges, but myself and many others use Ron G's fitting.
That is what I used to mount mine. Mounting the sensors was done with the following: http://huryde.station180.com/gallery/view_photo.php?set_albumName=mikecampbellakaSY2932&id=aae
http://huryde.station180.com/gallery/view_photo.php?set_albumName=mikecampbellakaSY2932&id=aad
The clips are fuse holders from a fuse box for 600 volt fuses (had to buy an entire fuse box just for the clips :-?). I bolted mine to a plate and mounted the plate behind the washer reservoir. I also used a short length of silicone tubing between the plate and firewall to dampen some of the vibrations. HTH's
Mike Campbell
Ty 1450
Thanks for the tips, I'm going to try a setup like Ron's so i can get it setup for now. I may go back later and try to set it up like yours Mike..real nice setup man like the hidden look.
