Spark Blowout...
UR50SLO
V6+2=LSXCamaro
Spark Blowout.....
After alot of trying to be able to post on the site all is sorted out.. whew.. .thanks for the guys who helped streighten that out...
I have a question about spark blowout... Being a Turbo Buick guy we don't have this issue on the Buicks...
Why do Ty's need to have such a small gap to keep from blowing out?
Does a MSD 6AL solve that problem?
Would the Denzo Iridum plugs solve it? Duttwiler has had success with the plugs on difficult combustion chambers that tend to blow out the spark...
Any other suggestions to keep this from happing?
Have MSD wires,new cap,rotor and a Accell coil. CR43TS plugs at .30.. Blows out at.35
Confused...? I sure am...
Thanks for any help,
Scott~
jwaller
Evil Genius/SyTy Guru
Re: Spark Blowout...
not to tell you your bussiness but the truck calls for CR42TS's not 43's. either way I'd switch to Ur6's at 30 thou. trucks with stock heads dont have this issue unless your running an untuned alky system or you have voltage issues with your ign system. A 6 series MSD is better than stock but a Dig 7 is what I like to use with an HVCII coil. never had an issue with them not lighting things off.
now quality and MSD are another question but when they are working it's a great thing.
Beavis
Still plays with trucks
Some [eople have this prob, most don't. One thing I see is you are using the wrong plugs. You may want to try some NGK UR5's or UR6's(colder plug). I use those with great sucess as wel as many others. If you want a stock plug, I think they are the cr42's. Might want to double check that though. :tup:
Waller beat me to it
UR50SLO
V6+2=LSXCamaro
Only stupid questions are the unasked one's right?
That's why I asked... The local parts store said the 43's were stock and they did not carry the 42's...
I'll get a set of NGKs and try them. The engine is stock. I'll look into anonther coil. The one on there looks fairly new but could be going bad......?
Running 15-16psi... should not blow it out...
Thanks for the feedback... I'll make the switch this weekend as I'm getting prity good at changing them by now.. lol.. :rotf:
Thanks again,
Scott
